Planned Mods thread.
Re: Planned Mods thread.
Postby needfordspeed » December 16th, 2007, 11:47 pm
Future plans:
-Buy XR6T
and until then:
-FInish wheels off
-Sort out something about timing chain
-New clutch+lightened flywheel
-Put the tickford kit on
-MAYBE wheels.....
Been Liked: 417 times
1988 Ford S Pack
Postby Steady » December 17th, 2007, 12:12 am
Steady the MARTYR! wrote:Sprint
- Strip Daves car to copy his bracket and pullies- Done
- Get Wolf V500
- Install V2 SQ + V500 and assorted other bits , get tuned and run 6-8psi
- Build up Lokka diff with 3.7 gears
- Test fit Daves FR19s Done
- Take coil off rear springs
- Buy FR19s
ED Fairmont
- Clean + polish Done
- Degrease engine bay, fix oil leaks
- Fix rear power window reg that dan broke sort of done, block of wood holding it up
- Tyre shine stockies
- Sell
Tornado
- block BOV
- dose pipe
- tint windows
- lower it a bit
- get carbra
- rice up engine bay
Postby Amon » December 17th, 2007, 6:01 pm
ED
-Flash tune or something similar (heard flash tuning can be done to pre-au falcons now)
-3.9 gears in diff
-Fit thermos
-find some nice 18" wheels
-get a car jack that works :o
-better sway bars
-clear tail lights :)
-white background for dials
Beef or chicken ming mongs
Amon
1994 Ford XR6
Postby [Sterling] » December 17th, 2007, 8:15 pm
EF
-slotted brake disc's
-chipped
-lowered (thinking superlows)
-shift kit
-white dials
-tomorow ill be putting 18" FPV cobra rim's rollin on HP khumo's
-spoiler
-and fix bonnet and random scratch's
Postby ed40 » December 17th, 2007, 10:49 pm
ED
tune for 10psi
dummy fit cooler and piping
trim scorcher bar
adjust exhaust brackets to stop knocking
hide more wiring
trim and paint the wooden base on which the battery box sits
ed40
Has Liked: 191 times
Been Liked: 137 times
Postby [Sterling] » December 23rd, 2007, 7:49 am
EF
-chipped
-shift kit-DONE!
-white dials
-tomorow ill be putting 18" FPV cobra rim's rollin on HP khumo's-DONE!
-spoiler
Postby Airved » December 26th, 2007, 6:58 pm
Planned mods for future:
-Take out loan
-Buy EL xr6
-Chuck on current springs, zorst
-Plug n' Play ECU
-Supercharge it
-Buy 18" FPV MkII Rims
-Custom paint-job
-Cruise
As for the EA:
-Keep thinking about manual conversion and better diff
-Drive her til end of uni, when i'll have money again
-Sell it, part it, or give it a bushbash send-off (by the time uni's over, she'll probably be on her last legs anyway, given the lack of time/money I'll have to keep her in good order/fix broken stuff)
'89 EA S Pack
Tinting, tinted tail-lights
Super lows all around
Crow 222825 cam
Stage 2 Shift Kit
:( TOTALLED :(
Airved
Postby Dansedgli » December 27th, 2007, 2:02 pm
EA:
Move EB2 fairmont interior from shed into EA.
Move XR6T turbo setup from the maverick's front seat to EA.
Move koni reds and pedders springs from under the house to EA.
Make 250rwkw+
Get air con working.
Optimize tune for economy then use it as a daily when required.
Fit an auto or a lighter clutch.
Maverick:
Exhaust and extractors to replace my cracked and broken current setup.
Rebuild the carby when I cbf. LPG FTW.
Buy a bullbar.
Chop rear guards for clearance.
Move front diff forward 12mm for clearance. Done
Replace rear diff when it finally stops turning the wheels.
Fit an onboard air compressor.
Build drawers for the back for more storage space.
Lockers front and back when I win the lotto.
Postby Sunboost » December 27th, 2007, 2:09 pm
MRDOSE -
Nothing CBF
TUFPAK -
Nothing CBF
Postby Amon » January 14th, 2008, 4:47 pm
ed xr6
fit thermos (if and when i can get the clutch fan off)
fit slotted rotors when i cbf
fit 3.7 gears in diff
get tyres for new wheels
oh and wash the damn thing
Amon
1994 Ford XR6
Postby 67rce » January 19th, 2008, 3:19 pm
Plans for the EF are - fix zorst, new tyres, sell
AU- Sell, to buy a Sprint
67rce
Has Liked: 170 times
Postby [Sterling] » January 19th, 2008, 3:30 pm
EF
-chipped
-shift kit-DONE!
-white dials
-spoiler
-get manual and fit it
-put new rocker cover on (all shiney red one!)
Postby smokin ef » January 20th, 2008, 12:41 pm
5sp ef futura
within next 6 months..
* get my rims 20" xoni cyclops with white walls
* lower more - just done ultras all round :D :D
* rip shift short throw shifter
* finish cutom boot install
* finish custom interior.. changing from white 2 black (whites way 2 impractical 4 a daily considering im a plumber lol)
* finally get my new personalised plates
within next 12 months..
* hopefully get a jim mock stage 2 fullflight turbo setup approx 320rwkw!! fark yea!! haha :mrgreen:
5sp ef futura
smokin ef
Postby Dansedgli » January 30th, 2008, 1:26 pm
EA:
Wreck and crush
Maverick:
Buy a bullbar. Done
EF:
Replace brakes
Fix unusual trans behaviour
Get RWC
Lower it.
Find and fit tufcaps
Fit ECU and get it running good.
Turbo
Postby Malakai » January 30th, 2008, 5:01 pm
Install new fuel pump, 42lb injectors, 2:1 fuel reg.
Build my megasquirt and install it, get it running then get it tuned.
Get new 3" exhaust when I can't stand the leaks in the current exhaust any longer.
Within two years: Buy a BA Mk II XR6 Turbo (six speed of course) in Mercury Silver and just drive it till the mod bug bites. Keep the EA for special occasions or maybe not, haven't decided yet.
DISCLAIMER: The plans expressed above may change at any time. These plans may contain confidential, proprietary or legally privileged information. No confidentiality or privilege is waived or lost by any mis-transmission. If you receive this message in error, please immediately delete it and all copies of it from your system, destroy any hard copies of it and notify the sender. You must not, directly or indirectly, use, disclose, distribute, print, or copy any part of this message if you are not the intended recipient.
Postby TUFED6 » January 30th, 2008, 5:29 pm
Retire to tropical paradise
Die
Postby BI6TIM » January 31st, 2008, 2:03 pm
Update on plans for my ED Futura.
Put bonnet and front bar on.
Get rego.
Run motor in.
Go Farken Drifting!!!
BI6TIM
Postby fordbaby » January 31st, 2008, 2:10 pm
spray my car black, xr kit and supercharge it.
fordbaby
Stickers
Stickers
Postby [D1SCNT] » February 6th, 2008, 5:36 pm
ED Ghia
sell it...
Buy XR6T BA/F ute or VY SS 6speed LS1 ute or VZ calais...
[D1SCNT]
Postby burnt turtle » February 6th, 2008, 7:59 pm
SLOLS1 wrote:VZ:
Ready to put in
Extractors, highflow cats, ultralows, stereo setup subs all that (have all this too damn lazy to put it in!!!),
In the future
19s, hsv cluster and gauges, senator bootlip spoiler, hektik engine covers, mafless tune, OTR CAI, 3.73 lsd, 3000rpm high stall, stockies, lots of skidz..... pretty much what any holden driver plans LOL.. vortech maybe one day in the future.... not soon
If i dont sell it and get sick of it and do all that shit might buy somethin cheap most likely a ford of some sort i can take to work and kick around on site
iv got a mate that is sellin his dash gauges 4 a VZ monaro u want?
burnt turtle
Has Liked: 62 times
2003 Ford Fairlane
Postby Gunns » February 20th, 2008, 1:09 pm
TUFED6 wrote:Retire to tropical paradise with lots of hot naked flange
Die
Fixed
Gunns
1989 Ford SVO
Postby Dansedgli » February 20th, 2008, 1:23 pm
Maverick:
Exhaust and extractors to replace my cracked and broken current setup.Done (ghetto fixed)
Buy a bullbar. Done
Fit new flares Done
EF:
Replace brakes Done
Get RWC Done
Lower it. Done
Nitrous
Postby EFFalcon » February 20th, 2008, 1:27 pm
In order:
EA Wagon
- Fit EL Dash/wiring Done
- Fit 5.0 Done
- Slap some wheels on it Done
- put it on LPG
EF Turbo
- Swap Motor (rebuild + headwork)
- Fit Highstall
- Get Kit back on.
- replace paint
Postby pHaT`eL » February 20th, 2008, 1:33 pm
EL..
Spray bonnet DONE/front bar/rear bar
EL Ticky kit - Not doing anymore
Ultralows for the rear - Not doing anymore
Touch up small chips and scratches DONE
Put XR cam in until I get Dev 3 or 4 - Its in the boot..
New leads/plugs and panel/pod filter
White venetians
Possibly red wall tyres
Win best EF/EL at AFD :D FAIL
Postby Jim Beam » February 22nd, 2008, 10:04 am
EB II Fairmont
Chuck in a working stereo.
Pedders SL's and GSR.Done
Fix dent in bonnet or get new bonnet.
Eventually pull off the road (wont happen till at the earliest next year). Done. Fucking headgasket
Buy cheap shitter to get around in.
Snort stage 4 turbo kit, EMS 8860, 220rwkw till auto dies, then new tougher box.
Jim Beam
Postby Dansedgli » March 17th, 2008, 12:07 pm
Getting there.
Maverick:
Exhaust and extractors to replace my cracked and broken current setup.Done (Paceys and sports system)
Replace rear diff when it finally stops turning the wheels. Bought
Lockers front and back when I win the lotto. rear locker purchased
EF:
Replace brakes Done
Fix unusual trans behaviour Done
Get RWC Done
Lower it. Done
Nitrous
Postby Dansedgli » March 25th, 2008, 7:59 am
Updated list.
Maverick:
Sliders
Rear Bar
Front locker
EF:
Finish Nitrous install
Postby slo_sprint » March 26th, 2008, 12:12 am
EB:
Pull motor and box out as spare
Strip it and sell what i can
Ditch the f'er
Sprint:
New Pads and rotors
Fix massive eff off oil leak
New airbox setup
New Back Tyres :lol:
Fit New Flywheel and clutch with Rebuilt T5
Rebuild Diff with lokka and shorter ratio
New Carpet Inside
More Power
Suspension Work
Wheels
Respray
slo_sprint
Postby Tocchi » March 26th, 2008, 1:54 pm
FG XR8:
- wait for Ford to make mine (mid June they say :( :() ... i want it now!!!
- keep stock until warranty ends because ive got a bad habit of modding my dailys
EF XR6 Turbo:
- finish off the (complex) heat shielding in engine bay
- cut, buff, polish & wax thingo.
- take it to drags for a final 1/4 time
- sell it
XG ute:
- tub it
- finish BA front end conversion
- cage
- get the Phoon motor running :)
- crack 500rwkw
FG XR8 -- [RU 16 WA]
Simmons FR19s, Brembo 6 pot [f] 4 pot [r], 5% tint, Malwood 'Option 3+' clutch, Tein coilovers + EDFC, Whiteline adjustable swaybars, GTE bootlid spoiler, 2x Bride Zeta 3 fixed back seats, Volk TE37 track rims
EF XR6 Turbo -- SOLD
1971 Capri
shitty Garrett T51, pathetic fuel system (dash 10 earl fittings and lines, Prostar 750s x 2, 2433cc Siemens injectors, Process West fuel rail).
Atomic Chrome Moly Flexplate ... built powerglide transbrake etc
quite embarrasingly shit
Tocchi
Postby EF ECTIV » March 28th, 2008, 12:44 am
good work matty..... We were talking about your ute the other night..... Tub that bitch :twisted:
EF ECTIV
2013 G6E Turbo
Stock daily
EF ECTIV
Has Liked: 166 times
Postby Stengord » April 1st, 2008, 3:35 pm
Exhaust and paceys
Tint
Headwork
BA GT's hopefully 18
super lows al round
thats it for now
1985 BMW 318i
Stengord
Postby Nikk O'lass » April 4th, 2008, 5:48 pm
Blueprint for a better ED: Mission impressionalbe
-Make rear end inline with rest of car
-Install LSD, with New swaybars, Bushes, Possibly Lower springs
-Upgrade breaks
-Remove 14 years of carpark dents
-Paint it, custom 3 layer Le Mans red pearl
-Turbo, if the balance is favorable
-New wheels, maybe, if i cant get a replacement
-Mild interior rehash (Prob just some basic buckets and shit)
Been Liked: 125 times
Postby 4LEDboy » April 4th, 2008, 8:22 pm
My ED
Engine
CMS stage 3 cam, head, valve kit
ACL Race dished pistons
Pacemaker Extractors
Shine up rocker cover and Intake
XR6 computer and fuel reg
CAI Induction
Trans
Big cooler
Shift kit
Temp gauge
Electronic Shift kit
Diff Gears
Paint
Cut, Polish
fix stone chips
And ah yeah :shock:
4LEDboy
Postby braiden » April 4th, 2008, 9:04 pm
New List:
ED:
New Shocks / Struts
Boot Install
Turbo
Escort:
Finish stripping the car
Respray
Rebuild Engine (maybe turbo)
Rims
Lower
etc, etc
BF MkI XR6T
braiden
Postby Stengord » April 4th, 2008, 9:07 pm
What year escort?
1985 BMW 318i
Stengord
Postby braiden » April 5th, 2008, 4:44 am
abcisfun wrote:What year escort?
1980 IIRC. 2.0L Ghia.
BF MkI XR6T
braiden
Postby holmsy » April 9th, 2008, 8:01 pm
holmsy wrote:mine is slowly getting there. but very slowly.
-replace or fix multiple problems with the engine
-17 or 18 inch mags
-will be happy if i get 130-140 rwkw
-get lsd
iv done allright.
done more then planned but still no rims.
so far have replaced engine.
put in au motor
got lsd 3.45
finished all the au seats and console,
finished colour coding exterior,
and more little thingss
still to do:
mags
short shifter
hiflow cat (this week)
ecu
not sure how the power aim is going. should be getting up there soon.
Has Liked: 182 times
Been Liked: 154 times
Postby Jtalor » April 13th, 2008, 6:28 pm
ED Falcon Wagon
Soon Mods:
A new Kenwood CD player (This week, my first ever car mod! :D)
Buy a sub or two and an amp
Lower 2"
Later Mods (next 4 years...realistically haha)
New wheels, 18''s
Turbo it with all necessary mods.
Re-spray in dark metallic blue.
with that I would be very happy :)
Jtalor
Postby [Sterling] » April 13th, 2008, 7:03 pm
EF
-chipped-Swaped with XR6 ECU-DONE
-shift kit-DONE!-SOLD!
-white dials
-18" FPV cobra rim's rollin on HP khumo's-DONE!
-get manual and fit it-done
-put new rocker cover on-DONE
Postby Amon » April 16th, 2008, 9:14 pm
ultras and t5 conversion
Amon
1994 Ford XR6
