InfernalTyrant wrote:So now that you've figured out the problem, I just wanna ask what limp home mode actually is/does?
Jake wrote:InfernalTyrant wrote:So now that you've figured out the problem, I just wanna ask what limp home mode actually is/does?
It locks in 3rd gear and doesn't down shift or up shift... to help make less heat or something to get it home i guess?? someone else who knows better can give more detail if they want
I've been noticing my car goes into limp home mode sometimes when I start it, I restart the car and it goes away... its happend about 3 times in the last couple of months... its not bothering me at the moment but what could be causing it? the box / car drive perfectly fine any other time...
misk wrote:LHM is also setup to be no power sent to either S1/S2 solenoids so the box will give enough operation to drive the car even with no power sent to the box at all.
have you done shit like cleaning the connectors on the looms?
ive driven mine plenty of times on low fluid (to the point it would slip in and out of gear) and never had it go into LHM, but did have it once with some dirty connections.
