Dyno tomorrow...lets max out this little turbo
Postby old_mate » September 4th, 2012, 10:31 pm : wombi90 Likes this post
Finally getting on the dyno tomorrow. Car has been running really well (original owner did Process West stage 2 cooler, 100cpi cat, drilled injectors, tune at Elite Automotive) and it spat 280 odd rwkw last november on a 30+ degree day on about 11psi.
Also has a ZF tune which kind of fucks the whole experience. Too harsh. Elite would have continued to get my business however they really didnt seem too interested when I asked about touching up the box tune. Which is a shame, Paul took me for a blat in their blue F6 and that thing is quick.
Tomorrow Clinton from ProFile autosports now gets triple the coin Elite would have for a new fuel pump, 12psi actuator and some dyno time for a complete retune. You unfortunately cant adjust the zf tune independantly, you have to retune the whole shebang when you change tuners.
Hoping to wind as much boost as the little turbo will allow, and praying the valve springs arent going too soft. Am expecting 320rwkw on about 15psi depends on the injectors as well as the springs. I really enjoy the FG turbo, it spools so damn fast and I can chop many higher powered BA/BFs until about 80ks on the street. After that im toast haha.
Once im used to it this time, next round will be ID1000's, full exhaust, valve springs, GTX turbo and as close to 400 as I can get. Hopefully E85 becomes more readily available soon too, would mind getting on that train.
Somewhere in the middle, i want to put 4pot Brembos on the front, upgrade the rears to F6 spec, Bilstein shocks and a trutrac rear end.
G6E Turbo.
old_mate
Re: Dyno tomorrow...lets max out this little turbo
Postby needfordspeed » September 4th, 2012, 10:34 pm
Sounds good man, seems like ProFile Autosports are pumping out heaps of 600+rwkw DOHC 4L's so it should be in good hands!
Been Liked: 417 times
1988 Ford S Pack
Postby 67rce » September 4th, 2012, 10:34 pm
Moving away from Elite is a good idea! The bill and the quote are two completely diferent things there! Should be fun with the new mods!
67rce
Has Liked: 170 times
Postby nothin suss » September 5th, 2012, 7:41 am
Should be easily achievable. I would have thought Cooler and Cat would have seem over 300 already?
Mate just had his G6E tuned, all std, just a flash and pumped out 279rwkw from memory.
Next step is the subtle intake muffler restriction and the tuner is keen to see nearly 300?
The age old argument of dyno readings being high/low comes into it then.
BF2 DLPG Wagon - daily duties
BF Fairlong Ghia - ED Sprint
nothin suss
Has Liked: 223 times
Been Liked: 90 times
Postby needfordspeed » September 5th, 2012, 2:47 pm
Pitlane performance done some testing of the fg fuel pump, the standard item may not be as safe as you think at 300+ take a read on the xr6t forums.
1988 Ford S Pack
Postby old_mate » September 5th, 2012, 8:16 pm
Interesting day.
New fuel pump and actuator went on ok, initial tune went in (zf program back as per factory) and we drove down to the dyno.
ZF was instantly nicer, except it developed a strange tendancy to slip, forget what gear it was in and try upshift/downshift at very light throttle. We assumed it was just learning how to be a ZF again and the problem disappeared on the dyno. Or so we thought.
Once on the dyno, it quickly became apparent no more power would be made. Its falling very flat, very quickly in the top end. Looks like my 85000k valve springs have nothing left to give. Ended up with 288rwkw.
I'll post the dyno printout tomorrow. ZF played up quite a bit on the way home, so going to focus on that first.
G6E Turbo.
old_mate
Postby old_mate » September 5th, 2012, 10:01 pm
Today's Sheet
The last run done 20 thousand clicks ago.
Obligatory photo of car on rollers
G6E Turbo.
old_mate
Postby tx5_brent » September 5th, 2012, 10:43 pm
Torque drops a lot at 5600rpm, but before that its not that as bad as it looks because of the different scale.
Self-control is not doing a roll-on on the freeway at 100km/h,
Self-conservation is knowing when to lift.
Gone: AV TX5 turbo "Ted" usual mods, sold. GD 626 Turbo, big turbo, brass button clutch, solid engine mounts, 25 psi, crushed.
Current: AU Fairmont Ghia. XR250.
tx5_brent
Has Liked: 25 times
1999 Ford Fairmont Ghia
Postby old_mate » September 5th, 2012, 11:08 pm
I know power hasn't dropped off, was just putting comparison pics up there.
Fact remains - it should be shitting in well over 300.
G6E Turbo.
old_mate
Postby Parfrey » September 5th, 2012, 11:53 pm
On the plus side it should be sick with new springs... even if the old ones weren't totally stuffed (I know they are in this case) new ones wouldn't hurt.
Nice car too! Hmm i need cash for mods! lol
FG GT335 Tune only 376rwkw
GU Patrol TD42t @30psi
Parfrey
Has Liked: 82 times
Been Liked: 131 times
Postby old_mate » October 23rd, 2012, 6:26 pm
Injectors replaced (thanks Justin)
Now definately require some valve springs.
Not going to spend anymore time or money on it until the weather cools off again next year, I'll save up some cash for valve springs and go from there.
G6E Turbo.
old_mate
Postby Rollin » October 23rd, 2012, 7:42 pm
You sure it's the springs? Cars I've seen with soft valve springs usually have a really bodgy curve, it's all over the shop. Definitely not partially melted cat or some kind of exhaust restriction?
Postby old_mate » October 23rd, 2012, 8:04 pm
Possible - the 100cpi cat is only 12 months old, and its a factory exhaust after that. Apart from a straight through muffler that replaced the factory centre muffler. So unlikely. But possible.
The motor has now done 90,000ks, 30 of which had the boost wound up. I really should be doing the springs anyway as maintenance.
I may, just may end up throwing some sort of exhaust at it when the next round of enthusiasm strikes. In fact I probably will just to eliminate all possibilities.
These little turbos tend to max out at 330rwkw anyway, and i'm not particularly interested in going to a GTX core. How far does one go.
G6E Turbo.
old_mate
Postby Rollin » October 24th, 2012, 12:21 pm : ausedwagon, Bipolar, DJV8T5, Ef_frmnt, FairmontXR6, Fritzz, LUXO_8 Likes this post
......until it wheelspins uncontrollably in every gear.....?
Postby 09SR5 » October 24th, 2012, 5:15 pm
Rollin wrote:......until it wheelspins uncontrollably in every gear.....?
Even 6th haha
09 Hilux SR5 4X4
Gun Metal
3.0l Turbo Diesel
5 Speed
Toyota Alloy Bull Bar
IPF Driving lights
Goodyear Warangler MTR tires
09SR5
Been Liked: 35 times
Postby Rollin » October 24th, 2012, 8:17 pm
Do you really need to ask me that question? :D
Postby crusty2 » October 27th, 2012, 10:25 am
Rollin wrote:You sure it's the springs? Cars I've seen with soft valve springs usually have a really bodgy curve, it's all over the shop. Definitely not partially melted cat or some kind of exhaust restriction?
Good point,my ef was having issues similar to the car above,apc did the original owners tune....needless to say the cat melted into a molten ball andthe car was all over the place power wise.
Pulled the inernals out of cat and the difference was worlds apart.
Nice car,hope you achieve your wanted power levels. :)
EFxr6 turbo,c4 good for 750hp,sm4 autronic ecu,65lb siemens decka injectors,mike vine t04B custom turbo and manifold and piping,stock as a rock bottom end with decomp plate and standard intake manifold,making 370kw atw at 20psi.
making general owners cry on a daily basis.
crusty2
Has Liked: 23 times
Postby old_mate » June 8th, 2013, 2:48 pm
few little upgrades has this now sitting at 366rwkw @ 19psi, tune was done very quickly and has no timing into it, will be back on dyno next week.
aiming for 400.
G6E Turbo.
old_mate
Postby old_mate » June 8th, 2013, 2:49 pm : Bipolar Likes this post
G6E Turbo.
old_mate
Postby Rollin » June 8th, 2013, 4:14 pm
:D
Postby needfordspeed » June 8th, 2013, 4:28 pm
You'll probably need a LSD after this round of mods!
1988 Ford S Pack
Postby old_mate » June 8th, 2013, 6:16 pm
indeed I will. It pegs now like all VN's wish they could.
will probably need another ZF
And a tailshaft
maybe F6Garage can assist with some parts lol
G6E Turbo.
old_mate
Postby needfordspeed » June 8th, 2013, 9:56 pm
Definitely can, got a G6ET with 50,000kms :D
What day next week will it be back on the dyno?
1988 Ford S Pack
Postby old_mate » June 8th, 2013, 10:21 pm : needfordspeed Likes this post
Fryday at this stage
Sent from my GT-P7510 using Tapatalk 4 Beta
G6E Turbo.
old_mate
Postby Parfrey » June 8th, 2013, 10:40 pm
Nice effort so far! loving the black turbo housing too.
Swap you my lsd for your mods?? :-P
Is your auto starting to misbehave?
Parfrey
Has Liked: 82 times
Postby old_mate » June 9th, 2013, 10:57 am : OED666 Likes this post
nah auto loves it for now, but I can see flogged clutches and a snapped input shaft or two in its future.
I have an LSD center kicking around but i'm thinking about going a truetrac
G6E Turbo.
old_mate
Postby old_mate » October 7th, 2013, 2:04 am : Rollin, SLY5LT Likes this post
Never updated this, ended up at 373rwkw on 19 psi with factory intake arrangement and 380 same tune with turbo side. Have been meaning to run it up again on ultimate as it didnt takemuch timing on vortex but no point wringing it when E85 is available around the corner. Should go 440rwkw on that stuff.
Bolted coilovers in and bought some brembos too.
Get it on E85, build the ZF, get a tailshaft and get a trutrac fitted - run a ten then leave it alone. 10 second genuine daily driver - a few years ago unheard of
G6E Turbo.
old_mate
Postby needfordspeed » October 7th, 2013, 2:28 am
They're such good cars, one down here with similar mods to what you're planning just went 10.8 @ 131mph, looked dead stock from the outside.
1988 Ford S Pack
Postby SLY5LT » October 7th, 2013, 2:58 am
ok...i'm a bit late on this thread...being a new turbo owner.
congrats, i've only had my G6E-T 2 month's... and being a V8 guy.... can see the many option's a turbo can bring HP wise :shock:
old_mate wrote:ZF was instantly nicer, except it developed a strange tendancy to slip
i have noticed that from time to time as well.
old_mate wrote: I really enjoy the FG turbo, it spools so damn fast and I can chop many higher powered BA/BFs until about 80ks on the street. After that im toast haha.
it's good watching the face's of cammed commo's and last week a 390+ BF-F6 twist after HWY roll on's ...when you say your only making 290 :grin:
SLY5LT
Has Liked: 109 times
2003 Ford LTD
Postby Dumpsta » October 7th, 2013, 8:17 am
373 is awesome. I drove a cousins g6e a few weeks ago making very similar numbers. Incredible experience as I hadn't driven a serious turbo car. Easily the nicest looking cars around as well. G6et > F6 or Gt
Dumpsta
Has Liked: 28 times
Been Liked: 68 times
1997 Ford EL
Postby old_mate » October 7th, 2013, 9:57 am
A mate of mine is running 434rwkw still through an open diff - isnt as horrible as you would expect (except when standing on it when cornering - G6E owners shouldnt be doing such activities on the way to the bowls club lol). The MTA turbo I bolted on spools exactly the same as the little turbo did - so happy with it.
G6E Turbo.
old_mate
Postby old_mate » October 7th, 2013, 10:39 am : fordpatto Likes this post
Image prior to coilovers. Now sits much the same in the front and 10mm lower in the rear
Sent from my GT-I9305T using Tapatalk 4
G6E Turbo.
old_mate
Postby Dumpsta » October 7th, 2013, 1:18 pm
That is beautiful mate.
Dumpsta
Has Liked: 28 times
1997 Ford EL
Postby NUT347 » October 7th, 2013, 5:33 pm
I still see it around sometimes.
Still live in regents park?
Postby old_mate » October 7th, 2013, 6:06 pm
Yep. Sure do. I now also work with a bloke called adam who knows you pretty well
G6E Turbo.
old_mate
Postby NUT347 » October 7th, 2013, 7:25 pm
You work for secom?
Haha tripper.
Postby old_mate » October 7th, 2013, 8:08 pm
Not directly for secom, I work for a subsidiary business. Nothing to do with that hospital or the contractors onsite - thank ****. I'm sure you know what I mean :-)
G6E Turbo.
old_mate
Postby NUT347 » October 7th, 2013, 8:18 pm
Haha, I know what you mean.
