BA Falcon door lock actuator.
Postby sec » December 20th, 2012, 12:24 am
Hi guys so have any of your guys every had a god at disassembling a door lock actuator and fitting the recon kit, from what I gather its a plastic shaft with a cog and a small electric drive motor.
Looking at a photo it looks like yu just split the actuator and change the gear the only issue I see is if the little drive motor need the wire soldering to it.
Anyway what I am asking has anyone attempted this task and did they strike an issues.
A new Right front actuator from Ford is $219 a new one from eBay is $148 the recon kit from eBay is $50 so at $50 I am half willing giving that a go.
The new actuator on eBay is a genuine Ford part and according to the add its a upgraded version as in the BF Falcon and the supply the small wire harness to adapt it to the BA.
Maybe one of you guys may even know of a place to obtain one at a better price.
Well here hoping someone comes back with some info for me.
Ken.
Turned by L.G.AUTOMOTIVE Townsville
Garrett GT35/82R (water-cooled), 6Boost exhaust manifold, Turbosmart 50mm Wastegate, 50mm BOV & FPR800 fuel reg, Wolf V500 ECU & Boost Controller, 3" exhaust sys, Serge tank & Bosch pump, Bosch XSpurt 1000cc Inj, CamTech Cam CT006-845 + 114 LSA, Crow Valve Springs & Chome Molly Retainers &Collette locks, MLS –Head Gasket, TCE 9.5" custom converter.
sec
Re: BA Falcon door lock actuator.
Postby Simple6 » December 20th, 2012, 6:52 am
You can just buy a new shaft for $20 or so off eBay. I've done about 3 now but the first one I ordered was shit quality and broke straight away. The subsequent 3 were all fine. There's no soldering if you're just replacing the shaft and there shouldn't be a reason to replace the motor unless it's dead (my car was at 270k kms and the motors were all fine).
Only issues I had was connecting all the rods up. It can sometimes be a touch hard to get the drivers door working properly with the button and key, but you just put the actuator back in test it before putting the door trim back on and after a few goes adjusting the rods it was all sweet.
1997 EL Falcon XR6 Sedan
Cold Air Intake | Sequential Scoop | Pacemaker 4480 & 2.5" Exhaust
1976 XB Falcon 500 Wagon
Sherwood Green | 3spd/250CI | Hurricane Extractors + Custom Twin 2" Exhaust | Running Whitewalls on a 2.5" Drop
Simple6
1997 Ford EL Falcon XR6
Postby sec » December 20th, 2012, 9:50 am
Thanks for your reply.
I imagine that I shouldn't have to do any adjusting to the rods as I will be using the original unit shouldn't the adjustment remain as before??????
Ken.
sec
Postby agros ef » December 20th, 2012, 11:00 am
Hey mate I had to replace both actuators in my wife's wagon, instead of doing a reco I just naught reman actuators I think they were $40/50 each and still bolted straight in without having to adjust anything, they weren't changeover either and saved me stuffing up recoing them myself
agros ef
Been Liked: 24 times
Postby sec » December 20th, 2012, 11:10 am
agros ef wrote:Hey mate I had to replace both actuators in my wife's wagon, instead of doing a reco I just naught reman actuators I think they were $40/50 each and still bolted straight in without having to adjust anything, they weren't changeover either and saved me stuffing up recoing them myself
Sounds the way to go for the price, so where did you get them from I searched the internet and eBay for reco ones no joy.
Ken
sec
Postby Kyle the ED4LTR » December 20th, 2012, 1:26 pm
We do actuators on these things at work all the time, but $219 with the adapter loom is deer as!, probably because of your location too. I can do them for $138.65 with loom for Boosted Members. Just postage would be an issue :/
Postby Simple6 » December 20th, 2012, 2:31 pm
Sorry mate, I meant that when putting it back into the door it took a few goes to get the rods in the right way. Sometimes you get it spot on first go but other times it takes a second go of just moving where they sit on the actuator slightly to get a smooth movement. I used my existing actuator as well but still had an extra 5 mins or so just making sure it was working right with the door trim and not getting caught.
Simple6
Postby sec » December 20th, 2012, 3:59 pm
Are ok now I get it thanks
sec
Postby iCER » December 20th, 2012, 5:50 pm
if you like your chances, buy a 2nd hand one from wrecker/ebay for like $40.
Dyno-Mite Performance Tuned
iCER
Has Liked: 58 times
Been Liked: 57 times
Postby TAXI » December 20th, 2012, 7:09 pm
Au and ba have the same cog $2 for a few at upull it.
And easy to fit.
TAXI
Has Liked: 8 times
Postby TAXI » December 20th, 2012, 7:10 pm
And easy to fit.
TAXI
Has Liked: 8 times
Postby Simple6 » December 20th, 2012, 7:12 pm
http://item.mobileweb.ebay.com.au/viewi ... 1057133000
Pretty sure these are the ones I buy. I wouldn't chance a second hand one from a wrecker - whose to say it was die the next day? It's a risk.....
Simple6
Postby sec » December 20th, 2012, 10:43 pm
Thank for the help guys
sec
