will a microtech lt10c run a bf xr6 turbo engine
Postby ef_falcon_95 » January 8th, 2016, 5:10 pm
Hi all.
Currently I have sohc engine in my el with a t4 turbo . a microtech lt10c is running it all . my question is the rings are gone in the sohc . I want to replace it with a bf xr6 turbo engine . will the microtech run it .
I know the injector wiring should work. But I will have to rewire the ignition so it controls the coil packs . I don't want the dvct so I was going to lock the cams .
Can anyone give me more info on wiring in the coil packs and locking the cams ..
EL XR6, dark agents, bilstein shocks, extractors, 3" cat back , 5 speed, sunroof .
garret T04, 42lb injectors , 023, custom plenum.
ef_falcon_95
Re: will a microtech lt10c run a bf xr6 turbo engine
Postby ef_falcon_95 » January 22nd, 2016, 2:07 pm
Microtech replied to my emails. So Ive sorted it, how to run it with the lt10c.
Now since it won't run the cams, how to I lock the cams? Someone must know. Can't find any good info on locking up the cams. Thanks
ef_falcon_95
Postby NUT347 » January 29th, 2016, 10:10 am
Yeah you just need an x6 igniter box from microtech.
A few different companies make locked cam gears, crow, atomic, spool, etc.
Postby ef_falcon_95 » January 29th, 2016, 10:52 am
Thanks mate
ef_falcon_95
