E-series barra
E-series barra
Postby Tickford01 » October 1st, 2017, 3:22 pm
what would be the best way to get are barra in to xh loungrech with t5 trany
Tickford01
Re: E-series barra
Postby P100_Ute » January 29th, 2018, 1:22 pm
Notch the front of the sump to clear the K-Frame... get a AU T5 bellhousing.. Drill a hole in the side of the sump for clutch cable to go through to the bellhousing.. Attach the gearbox... open bonnet and lift engine in with a Crane... do up a few bolts.. install radiator and hoses and fill with coolant. fill up engine and gearbox with correct oils.. connect a couple wires and turnkey and enjoy..
P100_Ute
Re: E-series barra
Postby Fingers » February 2nd, 2018, 3:53 pm
This last bit might be a touch more involved
"connect a couple wires and turnkey and enjoy.."
Richard
Fingers
Re: E-series barra
Postby fordpatto » February 2nd, 2018, 4:59 pm
Try Everything Barra, looms and flash tunes.
They can probably help you.
Cheers Brian.
fordpatto
Has Liked: 51 times
Been Liked: 39 times
