by Drew442 » December 24th, 2017, 10:59 am
Take the front wheel off. Take the inner wheel liner off. Wind the window down with a battery. I don't recall the wire colors, you should be able to find a diagram somewhere.
The unlock button on the centre of dash is also always live, if you've got a stiff enough piece of wire that's long enough you can wedge the top of the door open and press the button with the wire.
Don't be tempted to smash the window, but if you must the main door glass is the cheapest piece and easiest to replace yourself. Don't smash any glass that's glued in...
Sent from my MI 5 using Tapatalk
