Fkn rust. Help?
Fkn rust. Help?
Postby Phillis » February 8th, 2009, 8:53 am
Ive got a problem with some rust in the dog legs of my car.
I had it taken care of in late october last year, but it seems that its already come back. The dog leg on the rear quater of the wagon has what seems to be bubbling underneath the new paint.
excuse the bad picture quality. Its clearly rust, and its on both sides of the car. The passenger side is worse than the drivers side.
The surface hasnt broken yet but im pretty sure it will soon. Its in a bitch of a place, and im wondering what kinda prices would be involved in getting 2 new rear quater panels and replacing these- Or would cutting the affected area out with a grinder and replacing it be easier?
Id take it back to the panel shop that did it originally but my mate works there and aparently ive been 'running my mouth' about his shoddy workmanship on my car.
Anyone else had rust in tight places like this? What'd you to go get rid of it?
I have a tiny tiny penis.
Phillis
Re: Fkn rust. Help?
Postby EFFalcon » February 8th, 2009, 9:02 am
Take a look at Benj's wagon on fordmods
http://www.fordmods.com/commercial-spon ... 4-360.html
Re: Fkn rust. Help?
Postby Phillis » February 8th, 2009, 9:12 am
Ive been following that build a bit, why havent i seen that part?
Man that rust makes me look like a little whinging b!tch.
Phillis
Re: Fkn rust. Help?
Postby EFFalcon » February 8th, 2009, 9:14 am
should see the rust in my wagon :P
Re: Fkn rust. Help?
Postby waghoonEF » February 8th, 2009, 10:31 am
Yeh mine has a spot of rust there aswell, not to stressed about it at the moment. I think the water comes in through the clip holes from the window trim mould and gets stuck in the dog leg of the EF wagons that has a rubbery like foam filled dog leg. When I do fix it I think I will dig all that shit out and spray some body deadener in there.
waghoonEF
Been Liked: 12 times
Re: Fkn rust. Help?
Postby LUXO_8 » February 8th, 2009, 10:35 am
fairlanes are also problematic in the dog legs...
mine has a bit which i will get onto this year
Has Liked: 1004 times
Been Liked: 132 times
1991 Ford Fairlane
Re: Fkn rust. Help?
Postby Dezza » February 8th, 2009, 10:40 am
I've also had rust at that same spot in the EA. I had it cut out probably about 4 years ago. The panelbeaters just cut a small square out, and welded in a new bit of steel. I've now got a small rust patch on the top of the guard but the dogleg still looks good
Dezza
1990 Ford Fairmont
Re: Fkn rust. Help?
Postby Phillis » February 8th, 2009, 10:43 am
waghoonEF wrote:Yeh mine has a spot of rust there aswell, not to stressed about it at the moment. I think the water comes in through the clip holes from the window trim mould and gets stuck in the dog leg of the EF wagons that has a rubbery like foam filled dog leg. When I do fix it I think I will dig all that shit out and spray some body deadener in there.
remind me to check out your rust :D
my biggest worry is that its going to keep going down, under the 'skirt' of the car, or around onto the flat part where the actual door covers when its shut. so replacing the dog leg is a hell of alot easier than replacing the panel?
Phillis
Re: Fkn rust. Help?
Postby Nikk O'lass » February 8th, 2009, 10:43 am
yeah thats a common problem with the E-series, its a water trap, water gets in, and there is some spongy foam that absorbs it. The ony way to fix rust is to cut it out, weld a new section in and treat the inside with some cavity wax etc.
Been Liked: 125 times
Re: Fkn rust. Help?
Postby Phillis » February 8th, 2009, 7:57 pm
so after talking to a few people today, its not as easy as cutting the dogleg out and replacing it with another. you wont be able to get a spot welder in there. hmm.
so who knows a good panel shop? i seriously feel so dirty for having rust in her :cry:
Phillis
Re: Fkn rust. Help?
Postby Nikk O'lass » February 9th, 2009, 8:35 am
Phillis wrote:so after talking to a few people today, its not as easy as cutting the dogleg out and replacing it with another. you wont be able to get a spot welder in there. hmm.
Bullshit, any panelbeater should be able to get a spot welder in there.
But, depending on how big the rust is, it may only need a small secion cut out, not the whole dogleg. Thats how we have done it before (On wagons)...
Re: Fkn rust. Help?
Postby rab » February 9th, 2009, 9:32 am
you dont really need to cut it out(if its rface rust and not eaten through making the panel thin).... just grind it all out.. it will spread like cancer unless you get all of it... and seal it immediately after its been done then fill it straight away.... any moisture on bare metal will cause rust immediately...whether you see it or not and cant be left exposed for any time..
WHOLESALEBLINDCOMPANY.COM.AU
0415-814-134
BLINDS/SHUTTERS/AWNINGS
rab
Re: Fkn rust. Help?
Postby Phillis » February 9th, 2009, 9:48 am
when i took the car in to get repaired the first time, they ground it out and spot welded a piece of steel back in. im guessing they didnt get all of it because its back now, just 3 months after it was fixed!
Phillis
Re: Fkn rust. Help?
Postby rab » February 9th, 2009, 10:43 am
yep, if they got it all, then it would be fine... there should be no pitting in surface at all...thats still rust...must be smooth..
0415-814-134
rab
