My Supra.
My Supra.
Postby proey » October 25th, 2013, 5:52 pm : Bipolar, nstg8a Likes this post
Hi all. I thought I should introduce myself. I've been reading and gathering info on here for a while. My name is Glenn I live in Newcastle. My daily is a hilux(tow vehicle). While my better half drives a series 3 AU Wagon. Basically stock except for the Lovells springs and shocks and the 17 inch wheels. The main reason for my interest here is my race car. Up until 12 month ago I was racinig an Escort Sports Sedan in the NSW Championship. Then the oportunity to buy a space frame car came up. So the Escort was sold and the supra was bought. It came with all the bits to make it a roller but no engine or gearbox. Yep I know what you are thinking. What is he doing on here with a supra? Let me explain. Being bit of a Ford nut and hearing about the Barra's making big power and wanting to be a bit different I started looking into a turbo 6. Class rule limit turbo engine size to 3.529L. So I started looking at the 3.2 from the EA. Then I found the 221 with its 87.88mm crank. So together with 200ci rods, Au pistons and a EA block bored to suit it comes in just under the class limit. Also because I wanted to prove this could be done and I'm on the tightest of tight budgets the motor was put together from second hand parts. I've had a couple of issues along the way. This year has been a learning year. Also being on such a tight budget my development gets done at the race meeting. Anyway thats the short version. So look past the fact its a supra and remember it's powered by a Falcon motor.
proey
Re: My Supra.
Postby markr154 » October 25th, 2013, 6:25 pm
Very nice!! Power figure?
Hot Chilli Red EL XR6, 5-spd manual, with BF F6 TYPHOON motor and supporting mod's, 3" exhaust etc etc.
298 rwkw @ 12 psi with re-tune likely.
My car here: http://www.pertheseries.com/forums/inde ... entry84622
NOW BOOSTED ...BF TYPHOON STYLE !!!
markr154
Been Liked: 29 times
Re: My Supra.
Postby private9 » October 25th, 2013, 6:58 pm
That's really cool!
private9
Been Liked: 185 times
Re: My Supra.
Postby Bob Lablaw » October 25th, 2013, 6:59 pm
love this sort of build, what ecu are you running and whats your rev limit you set, keep up the updates
245rwkw @ 8psi EF Fairmont- HX35 turbo, 42lb lucas injectors, 45mm wastegate, owner made exhaust manifold cooler piping, port and polish, 3" exhaust, super lows, 17x8.5 ROH z's, shift kit, XR8 bulge and extra vents, slotted rotors, J3 boost tune, wrx seats, wideband.... brake upgrade to come
Bob Lablaw
1996 Ford Fairmont Ghia
Re: My Supra.
Postby proey » October 25th, 2013, 7:08 pm
Still yet to get it on the Dyno. I've been doing my tuning at the track. Wouold be happy with anything over 400rwhp. The Escort had over 300rwhp and this feels lots stonger.
proey
Re: My Supra.
Postby proey » October 25th, 2013, 7:16 pm
Cheers guys ECU is a megasquirt 3. Rev limit is set at 6500. It's on the conservative side as there is no history of this combination. I would like to think 7000 to 7500 would be safe for the bottom end but not sure about the rockers?
proey
Re: My Supra.
Postby proey » October 25th, 2013, 7:27 pm
For more info on Sports Sedans go here.
NSW Sports Sedans
Pro Motorsport
proey
Re: My Supra.
Postby NUT347 » October 25th, 2013, 8:03 pm
That's awesome!!!
Re: My Supra.
Postby Rollin » October 25th, 2013, 8:10 pm
Yeah I like it :D
What do you think about the 221 crank? Is it just straight out of an early falcon and it went straight in...?
What intake manifold and PCV setup are you using? Looks like it had a little hiccup from your FB page :/
Re: My Supra.
Postby Frodo » October 25th, 2013, 8:13 pm
This is a very interesting combination. Good to see people are still thinking outside the box
BA XR8 with 238rwkw. PB 13.8 @ 103mph
Frodo
2004 Ford XR8
Re: My Supra.
Postby proey » October 25th, 2013, 9:17 pm
Rollin wrote:Yeah I like it :D
Crank Is almost a direct swap. Yep from an XT. 1968-69 falcon. I like it because of the stroke but I would prefer billet or forged. Inlet is the log manifold. Reusing pistons was the problem. One was weakened when being removed from the AU rod. Won't be doing that again. I've Also stripped the teeth off the oil pump drive to idler gear. Is this a known weakness?
proey
Re: My Supra.
Postby Rollin » October 25th, 2013, 9:34 pm
I don't recall seeing others on here rip teeth off the pump drive, but apparently they have problems with the auxillary drive wearing out in the front of the block - I noticed when building the motor for our car that the front main bearing can obscure or partially obscure the oil supply to the aux shaft if the hole isn't drilled in the right place. Something to check when you put it back together.
Make sure you run a catch can for the breathers (if they are being re-routed back into the intake) because in some situations it's possible to hydraulic number 6 and/or 5 by filling the manifold full of oil.
Re: My Supra.
Postby proey » October 25th, 2013, 9:46 pm
Yeah I read here about the oil feed. I modded the hole to give better oil flow. Even the one I have in now is showing signs of wear.
I run breathers to a catch tank so no worries about filling the manifold with oil.
proey
Re: My Supra.
Postby TUFED6 » October 26th, 2013, 9:24 am
Man what an interesting combo! Will be interesting to hear what the power delivery is like at 3.5L and if it changes the spread of power/torque
Re: My Supra.
Postby kwikxr » October 26th, 2013, 9:44 am
Very cool build! Interesting engine combo, good stuff :thumbsup:
Fun hack / Project - '95 EF Fairmont Turbo Link
Daily hack / Cruiser - '97 EL Fairmont Ghia Link
kwikxr
Has Liked: 90 times
Been Liked: 45 times
Re: My Supra.
Postby ed40 » October 26th, 2013, 12:01 pm
I'm in love, I'd really like to see the dyno graph for this car when/if it's ever dynoed.
I have always been curious to see how a 3.2 with boost would go.
JZ<4L
ed40
Has Liked: 191 times
Been Liked: 137 times
Re: My Supra.
Postby proey » October 26th, 2013, 8:52 pm
Thanks for your comments guys. I will definitely post up Dyno figures once its done.
proey
Re: My Supra.
Postby misk » October 26th, 2013, 8:57 pm
whats the actual bore x stroke now?
misk
Has Liked: 298 times
Been Liked: 295 times
Re: My Supra.
Postby proey » October 26th, 2013, 9:27 pm
Bore and stroke are 92.26 by 87.88. I'm also on the lookout for a 3.9 block that is good enough to bore to 92mm.
proey
Re: My Supra.
Postby SNR » October 27th, 2013, 10:31 am
This is cool.
Great to hear there's an option other than finding an EA 3.2 (which I've also been looking for for some time!)
What cam are you using?
SNR
Has Liked: 174 times
Re: My Supra.
Postby proey » October 27th, 2013, 7:28 pm
Ok thought I had better post up some engine details
EA Block Bored to 92.26.
EA log inlet manifold.
044 pump, 650cc injectors
221 Crank.
200ci Rods shot peened ARP bolts.
AU pistons
AU head Mild port job. Standard Cam (for now)
AU girdle
AU oil pump. Pressure relief blocked.
Remote oil filter, cooler and pressure reg.
EA Sump modded, 8 liter capacity
T04 Turbo.
Turbosmart Progate 50 wastegate.
6 into 2 into 1 manifold using standard exhaust and 2.5inch steam pipe.
Three inch dump into 4 inch exhaust.
221 flex plate
QuaterMaster 7.25 twin plate clutch mounted on a custom adapter.
EA bellhousing
T56 mounted by a adapter plate.
Remote custom shifter.
Boost set at 16psi. Before fitting the Progate boost would creep up above 20psi.
Independent 9 inch rear end.
Max spool 4.5 ratio
Glenn
proey
Re: My Supra.
Postby Jayedxr6 » October 29th, 2013, 8:18 pm
Just a tip mate, the later 91DA log inlet manifolds (eb2-ed) out flow the ea manifold. By a bit im told.....
Absolutely love the combo, cant wait too see a dyno sheet.
Re: My Supra.
Postby TUFED6 » October 29th, 2013, 8:38 pm
Did you really block off the oil pump pressure relief? That might explain why it stripped the pump gears
Re: My Supra.
Postby proey » October 29th, 2013, 8:43 pm : Jayedxr6 Likes this post
Jayedxr6 wrote:Just a tip mate, the later 91DA log inlet manifolds (eb2-ed) out flow the ea manifold. By a bit im told.....
Cheers for that. All bits of info like this are great.
proey
Re: My Supra.
Postby proey » October 29th, 2013, 9:01 pm
TUFED6 wrote:Did you really block off the oil pump pressure relief? That might explain why it stripped the pump gears
Yeah but I run a peterson remote pressure relief valve. I did have the pressure set at 80psi. A bit high. I'm used to the SR20 and the Cosworth from the Escort. Thats what I used to run on them but they would rev to 9000. I now have it set to 60psi and there a wear marks on the teeth.
The Escort block has a very sinmilar setup and it ran 80psi for years without problem.
proey
Re: My Supra.
Postby TUFED6 » October 29th, 2013, 9:17 pm
Ah right. Yeah 80 is pretty high. I'd be pretty worried about putting extra load on those gears if you look at them they aren't very beefy.
Sent from my iPad using Tapatalk HD
Re: My Supra.
Postby proey » December 23rd, 2013, 10:49 am
Here are some pictures of a EA, 200ci and 221 crank. Main differences are the balancing wieghts, rear main seal and flywheel bolt pattern of the 221.
proey
Re: My Supra.
Postby EFFalcon » December 23rd, 2013, 11:04 am
I missed this... love the idea.
Re: My Supra.
Postby proey » January 28th, 2016, 2:47 pm
On the dyno again getting ready for the support races at the 12h. 16psi. should do nicely for now.
proey
