What gears are best for a diff
Support/Suggestions/Questions/Answers
Postby Tidy xr6 » May 26th, 2014, 9:28 pm
Hi all I'm doing an upgrade on my diff and some suppliers have said to stay original with Borg Warner gears and some have said to change to Spicer gears.im doing the upgrade to get more acceleration.. :confused: :beg:
Tidy xr6
1994 Tickford Ford Falcon XR6
Re: What gears are best for a diff
Postby Jayedxr6 » May 27th, 2014, 5:37 am
Eithier will be fine. What ratio you going with? 3.9:1?
Postby DJV8T5 » May 27th, 2014, 7:28 am
Find what ratio you want, then find out which brand supplies the ratio you want. Also consider what type of driving you do when you consider ratio, as 4.11:1 may not be great if you do a lot of freeway driving. I haven't heard of diff gears failing without cause, so it would really come down to what is available
Has Liked: 216 times
Been Liked: 88 times
Return to Site Support
