Fastest 1/4 from a turbo 6 & stock engine
Postby oatsie73 » February 19th, 2012, 10:07 am
Just wandering what the fastest recorded 1/4 mile time is for a 300000k ef 4.0 is I've only done cam and cometic to mine and was curious to see what other people have achieved oh and turbo
EF Ghia 329rwkw 11.7 @ 121mph
Turbo by Snort Performance
Tuned by CVE Performance
oatsie73
Re: Fastest 1/4 from a turbo 6 & stock engine
Postby bentls » February 19th, 2012, 10:13 am
does the motor have to have done 300,000 exactly or can it be a little under?
Has Liked: 277 times
Been Liked: 158 times
Postby oatsie73 » February 19th, 2012, 10:17 am
Lol yeah like 180000 and above I guess what I'm saying is not rebuilt
oatsie73
Postby OMY-747 » February 19th, 2012, 11:35 am
Look at solid Ef turbo in elite build threads
OMY-747
Has Liked: 59 times
Been Liked: 58 times
Postby mad_keen » February 19th, 2012, 12:14 pm
A guy up here had the fastest unopened xr6t running 11something.
mad_keen
Has Liked: 25 times
Been Liked: 44 times
1996 Ford Falcon
Postby oatsie73 » February 19th, 2012, 1:00 pm
Sweet thanks guys. Solid ef runs e85 though and has done valve springs, I posted on his car it's f'ing awesome to read his results.
oatsie73
Postby misk » February 19th, 2012, 1:39 pm
You won't find many quick cars running standard valve springs
misk
Has Liked: 298 times
Been Liked: 295 times
Postby oatsie73 » February 19th, 2012, 1:55 pm
C'mon misk 11's are fast in my day 12's were nuts on a daily !
oatsie73
Postby TROYMAN » February 19th, 2012, 3:08 pm
im running 12s with a stock au xr6 bottom end and head on 12 psi...
i have ran it a few times on the street with 20psi...lol,,,
and yes still using std valve springs and std dizzy,,,
ed 4.0l turbo, 267rwkw on 12psi.. 12.5@113mph tuned by V@E RIGOLI
au 3 xr8 supercharged, unknown kw, unknown 1/4 mile at this time
TROYMAN
Postby oatsie73 » February 19th, 2012, 3:22 pm
Std springs and 20 lbs gives me hope awesome effort troyman
oatsie73
Postby TROYMAN » February 19th, 2012, 9:39 pm
although it does suffer alot of blow by at and over 18psi, after a few hard bursts it blew the dipstick out..lol..
the spark plugs are gapped down to.6mm to stop blow out.
i havent noticed any problems with the valve springs so far, but at 20psi i cant see it being trouble free for long, this engine has spent the last 2 years/30.000km on 12psi.
its currently at 15psi and now has better breathers and catch can and so far its all still good :D ...
TROYMAN
Postby bry40l » February 20th, 2012, 11:23 am
oatsie73 wrote:Std springs and 20 lbs gives me hope awesome effort troyman
by standard springs he means standard xr springs. standard falcon engines have different valve springs to the xr6 engine, so troyman would b running xr6 springs as he has the xr6 motor
bry40l
1996 Ford Falcon
Postby misk » February 20th, 2012, 11:54 am
Sorry i didn't mean to say that 11s aren't quick, just that most people upgrade valve springs at the very least when adding boost, so not many setups around using standard springs.
I could try my gt42 with standard au valve springs if you like? Lol
misk
Postby oatsie73 » February 20th, 2012, 12:16 pm
Lol misk or I could try your gt42 with my standard springs for you :D
oatsie73
Postby private9 » February 20th, 2012, 9:13 pm : ed40, rat Likes this post
Should join LS1 forums - plenty of different categories that you can make up to be number 1!
Seriously though, high 11s on an old banger is nice going!
private9
Been Liked: 185 times
Postby oatsie73 » February 21st, 2012, 8:32 am
LOL Private9 I'm not looking for No' 1 I'll leave that to the guys with the VL's, I was more curious if it's common to push em to 10's. I honestly though the first reply would be "Sinan did a 10.00 with a log manifold and stock 300k engine on street tyre's"
oatsie73
Postby OMY-747 » February 21st, 2012, 11:23 am
Dunno about 10.0. But he Sinan has always said stock motor and auto are good for 10's.
OMY-747
Has Liked: 59 times
Postby NUT347 » February 23rd, 2012, 8:05 am
Sinans best time was 10.7@ 121mph with stock auto and bottom end, but I'm sure he had head work.
Postby EBOOST » February 23rd, 2012, 10:30 am
do u really class valve springs as engine work?
u have a different cam thats more engine work than valve springs imo.
yeah sinan went 10.7 on stock bottom end not sure about the head.
that was with 280-330rwkw or something so urs should be close to that.
i was talking to him the night he ran it.
cheers josh.
Get Stroked!!
AU Stroked 5.6L Ghia.
EBOOST
Has Liked: 437 times
Been Liked: 93 times
Postby Mr. CVE » February 23rd, 2012, 3:54 pm
EBOOST wrote:do u really class valve springs as engine work?
cheers josh.
did you get to see under the bonnet ?
haha, just messin ! :D
http://www.cveperformance.com
Mr. CVE
Has Liked: 49 times
Been Liked: 188 times
Postby EBOOST » February 23rd, 2012, 4:46 pm
Haha this was ages ago before all the plenum stuff so yeah got to see everything.
cheers josh.
Get Stroked!!
EBOOST
Postby TURBO_GHIA » May 1st, 2012, 10:42 pm
michael ryans EB has run a 10.05 @132mph
HHmmmm booostttttt
EL GHIA TURBO
STREET FORDS FEATURE CAR ISSUE 42
TURBO_GHIA
Been Liked: 21 times
1997 Ford Fairmont Ghia
Postby AaronEF8 » May 2nd, 2012, 2:04 am
thread needs more Casper and carpet options.
AaronEF8
Has Liked: 55 times
Been Liked: 245 times
Postby TUFED6 » May 2nd, 2012, 6:55 am
Shit thread. Define stock engine?
Not many turbo falcons will still be using the standard valve springs or head gasket. Thats not stock to me.
Postby TROYMAN » May 2nd, 2012, 8:05 am
TUFED6 wrote:Shit thread. Define stock engine?
mine is...
mines still on the factory head gasket and std valve springs....
the only questionable part in mine is the cam.
imo a stock engine is stock bottom end, std head, std valve springs std compression..
TROYMAN
Postby Dansedgli » May 2nd, 2012, 8:11 am : Michael (HYPOEB) Likes this post
Is it questionable or aftermarket?
This thread should be called "create a class where I am the only contender so I'm no. 1. "
/wanksmilie
Postby OMY-747 » May 2nd, 2012, 12:11 pm
Catergise by number plates and states, sweet every car I've owned has been number one :drinks2:
OMY-747
Has Liked: 59 times
Postby -fairmont- » May 3rd, 2012, 7:35 am
OMY-747 wrote:Catergise by number plates and states, sweet every car I've owned has been number one :drinks2:
not if someone with a faster car gets your plates.
Chargd wrote:dont worry mate, it isnt your fault your mum and dad share the same parents.
obsezd wrote:Never knew they allowed grandparents to keep dynos at the retirement village
Bipolar wrote:Basically I park assuming everyone else is retarded.
-fairmont-
Has Liked: 51 times
1990 Ford POS EA
Postby OMY-747 » May 3rd, 2012, 8:50 am
How could they? Per state there is only the one number plate. Nobody else in Vic but me has OMY-747.
OMY-747
Has Liked: 59 times
Postby turbo_nut » May 3rd, 2012, 5:35 pm
dave cheehey done 9.8 at palmyra with his unopened ba xr6t
turbo_nut
Has Liked: 37 times
Postby AdamF » May 5th, 2012, 1:46 pm
My knob is slightly larger than yours.
Oh shit wrong topic, or?
Project- elxr6 with boost
Daily ED wagon which i think may require boost
AdamF
Been Liked: 12 times
Postby Rollin » May 5th, 2012, 8:45 pm : EBwag93, LUXO_8, rat Likes this post
This is awesome! - because of this thread I'm going to have the fastest EB Fairmont turbo that has been converted from auto to manual then had an AU motor fitted then converted back to auto then turbo'd then blown up then had another AU motor fitted then blown up again and caught fire then had a whole new interior and wiring harness put in with an ED motor which then had a VCT head put on then blown up again and then had a built motor put in with a non-VCT head (and will probably blow up again...).
How bloody good is that!!!!!!!
