Launching / Racing a ZF Turbo
Postby Sunboost » October 1st, 2013, 8:59 am
Wanting to take my FG down the quarter in the next few weeks so thought it may be time to start doing some research and practice on how to launch her.
It's running around mid 300's at the treads, will be running brand new average quality 19" street tyres which seem to grip a lot better than the Police spec Bridgey's it had on before.
I've heard a few and read few posts in the past regarding stalling it up in 2nd to build the boost, then down-shifting to 1st when it's ready to go and manually going through the gears. Other people have said performance mode without manual shift, stall up and away you go when ready.
Should DSC be on or off?
If anyone wants to lend me some tyres let me know :P
Running a ZF tune with factory heat exchanger / oil cooler so don't want to strain her too much even though I have access to 2 spare boxes lol.
Anyways, non Icer tips are appreciated.
Re: Launching / Racing a ZF Turbo
Postby TUFED6 » October 1st, 2013, 9:04 am
Non icer tip: You want to get it on boost before you leave the line. Foot brake it as much as you can before it starts creepin off. Really jam your foot down on the brake like your standing on Rihanna's neck. Even street tyres will benefit from dropping the pressure a little, maybe let 5psi out of them and see what happens. Also doing a burnout on street tyres has nearly no benefit - by all means do it 4DLOLZ but it will probably hurt your times.
Icer tip: You want to turn the boost up to 11ty and just try and make one good pass for a 9. Also if you just spend $30k-33k you can put in a powerglide and the whole problem just goes away. Also consider cutting the whole body off and replacing it with fibreglass. Easy 8z.
Postby Rollin » October 1st, 2013, 9:41 am
It might not be the same for every track but I've found in the past at willowbank that a bit of a skid does help, even with street tyres.
The trick is that you don't do a sick 4th gear standstill in the water and then lift off and drive out - you drive just past the water (or start in the water and immediately creep out) and then to a very low speed (but at full noise in first) short skid up to the line.
This bakes all the expensive sticky rubber from other peoples tyres onto yours, and they will grip better. Managed 1.9s on 17" street tyres with this method.
Postby Parfrey » October 1st, 2013, 10:45 am
Yeah a bit of a skid is the go.. only a small one.
I don't think you'll get much benefit out of stalling it in 2nd with street tyres.. it'll just bake them harder.
Also if it axle tramps or anything funky get out of the throttle asap.
FG GT335 Tune only 376rwkw
GU Patrol TD42t @30psi
Parfrey
Has Liked: 82 times
Been Liked: 131 times
Postby ed40 » October 1st, 2013, 12:12 pm
my mate launches his 9 second f6 with foot brake + handbrake in 2nd gear to build boost then off the line smash back to 1st
ed40
Has Liked: 191 times
Been Liked: 137 times
Postby nothin suss » October 1st, 2013, 12:47 pm
ed40 wrote:my mate launches his 9 second f6 with foot brake + handbrake in 2nd gear to build boost then off the line smash back to 1st
Should the little FG turbo need that much help boosting up?
Or maybe MID-300's it has a different turbo?
BF2 DLPG Wagon - daily duties
BF Fairlong Ghia - ED Sprint
nothin suss
Has Liked: 223 times
Been Liked: 90 times
Postby TAXI » October 1st, 2013, 3:57 pm
Don't know why people are saying smash it back to first.
Because if the zf works like the 4 speed You hold second let the brake off and let go of the shifter and it will leave in first.
TAXI
Has Liked: 8 times
Postby Jayedxr6 » October 1st, 2013, 4:18 pm
Dsc off, 2nd with brakes HARD on back to first very very momentarily later let go of brakes
Postby NUT347 » October 1st, 2013, 4:36 pm
Don't bother with second gear on street Tyres, it will go back to fist then immediately start limiter bashing.
Small skid, just first gear.
Hard on the brakes and leave it in sports mode.
Postby nstg8a » October 1st, 2013, 4:46 pm
I got my best time shifting manually, dsc off. But that was in a xr8, so the turbo torque might make a difference.
Postby fairmont4me » October 1st, 2013, 7:51 pm
definitely handbrake aswell, I found the typhoon wanted to creep a little, practice getting it on to launch boost as quixk as possible, if you sit on the stall to long the box freaks out and goes in to safety mode, revs will drop off and launch goes to shit.
fairmont4me
Been Liked: 12 times
Postby Jayedxr6 » October 1st, 2013, 8:10 pm
Yer true my experience with very little wheels spin but car is stock
Postby iCER » October 1st, 2013, 11:53 pm
dump the clutch from 7k bro!
Dyno-Mite Performance Tuned
iCER
Has Liked: 58 times
Been Liked: 57 times
Postby SLY5LT » October 2nd, 2013, 1:52 am
lol, spewing this thread wasn't up last week...took my g6e-t out to calder & being my first turbo car was chasing my tail on how to launch :this:
there's some handy tip's above that i'll try next time (after puting my LSD in as well) :grin:
SLY5LT
Has Liked: 109 times
2003 Ford LTD
Postby Sunboost » October 2nd, 2013, 10:08 am
ZF stays in second from the line. If you put it in Perf and select 2nd it won't go back to 1st like a BTR.
I'm scared to strain the box so hard but holding the brake hard to build boost.
My guess is it'll spin or tramp on the Tyres an run a 13 or snap the input shaft.
The 9s F6 someone mentioned would prob not be running a stock box or at least input shaft.
Postby EFFalcon » October 2nd, 2013, 10:29 am : galapogos01 Likes this post
first run, little bit of stall, leave it in performance mode, and let it do the work, after that try some more aggressive techniques.
Postby Parfrey » October 2nd, 2013, 11:21 am
Has yours got a stock tail shaft? That's the first thing I'd be worried about, but if its only on street tyres I don't think you'll have an issue.
I dunno what street tyres you other guys are running but I'm sure building boost in 2nd and going back to first or needing to use the handbrake and brakes to hold it will result in a 1/4 mile powerskid..
My EF loved 3000rpm+ and 10psi off the line with Mickey T's and a stock diff/tailshaft/BTR.... the FG will love it! haha
Parfrey
Has Liked: 82 times
Postby iCER » October 2nd, 2013, 11:43 am
fyi, with a 4sp btr u cant select 2nd from stationary. it will auto go back to 1st in pref mode. Unless it is a full manualized setup. But yes, stock tailshaft, mid 300s + ETs will not end up well with the zf.
iCER
Has Liked: 58 times
Postby ClassicAU » October 2nd, 2013, 11:49 am
Again, mine was a V8 not a 6T, but I killed the ZF by limiter bashing in first, so be careful there. I think mine was on the way out anyway though as it had towed before I bought it, but it only took a couple of manual flicks back to first to do a skid, I never even dragged the thing! Stalling mine on the foot brake in performance mode instantly resulted in wheel spin too.
ClassicAU
Has Liked: 34 times
Been Liked: 109 times
Postby TAXI » October 3rd, 2013, 10:34 am
iCER wrote:fyi, with a 4sp btr u cant select 2nd from stationary. it will auto go back to 1st in pref mode. Unless it is a full manualized setup. But yes, stock tailshaft, mid 300s + ETs will not end up well with the zf.
Yes you can,only goes back to first when ya let go of the shifter.
TAXI
Has Liked: 8 times
Postby iCER » October 3rd, 2013, 9:04 pm
what do you mean. In Pref i click it in 2nd on the foot brake and it auto goes back to 1st.
anyway im sure this is off topic. noone launches a 4spd like that anyway
iCER
Has Liked: 58 times
Postby xr6661 » October 14th, 2013, 6:25 pm
Put it in D for Drag, bit of stall and go for it.
xr6661
