galapogos01 wrote:Looking sick dude. Watch those bendy rods in the new motor, they don't handle detonation as well as the earlier models!
Jason
kwikxr wrote:galapogos01 wrote:Looking sick dude. Watch those bendy rods in the new motor, they don't handle detonation as well as the earlier models!
Jason
Cheers mate! Will do, last thing i need is an s-shaped rod in a motor that just got fitted lol, will keep timing fairly sedate for now and probably only go up to 10psi to keep it reliable. The tune is pretty much sorted now, is a little rich coming onto boost, but will fix that up this week and have it ready for the track this weekend
Motor swap was 2 weekends ago, fired into life on the first turn of the key too which was awesome. Sounds so much smoother now, and goes a hell of a lot better
Engine out
Hi stall fitted up
New engine in
Stacks of sump to k-frame clearance
Making a start on refitting the intake side of the motor up
Engine all put back together
After topping up the auto fluid after getting the oil pumped through into the empty converter, I just couldn't resist taking it out for a quick spin, with no bonnet of course haha. It's so much more fun to drive with the high stall, feels way more snappier than the EF motor ever did off boost and that's on a pretty average timing map so should be a lot more to come. Rev's out so much quicker and smoother too! Stalled it up at half throttle a couple of times and it jumps up to around 2800rpm, smashes the limiter into 2nd gear and just fries the 205 tyres on my Ghia wheels without any real effort. Would hate to see what it's capable of in the wet as it felt pretty scary in the dry lol. Took my brother for a spin and threw the car around a bit and it felt pretty good, so with a bit of a touch up on the tune, should be ready to roll at Hampton Downs race track for Chrome Expression Session this coming weekend.
The tyres on my Ghia wheels are down to the wire on the back now, so threw on a mint set of FTR's my brother bought as spares, turns out they look alright on the EF so will probably use these on Saturday at the track, and swap back to my black 17" ROH RT's for Sunday
Gazzajb wrote:Hey mate did you just drill and tap the au engine for the ef knock sensor did you have any dramas with it.
