GIFFS XF
GIFFS XF
Postby GIFFO97 » February 7th, 2013, 1:00 pm : Bipolar, sivart Likes this post
Okay, So I'm relatively new here, This is the first car i've owned or will own off my own back. I'm only 15 so cut me some slack...
It's an 86 XF Fairmont Ghia, Looks pretty Grandpa spec... 160,000KM's... Picking it up on Saturday.
Untill you pop the bonnet :shock: AU II XR6 Engine, Genie Extractors, XR6 Chip, 2 1/4" Exhaust... And obviously the plans are to keep up with the mowing rounds, Grab meself a part-time job, do me VCE and straight Gas, Boost it. Need to get it to run better than an 11.5 just to show up an old friend and his dads WK Caprice...
Anyway, Inside. All works, EF Dash conversion. Only one thing I'm going to change is the GLi Trim, to Fairmont.
Anyway, Thoughts an opinions wanted. What i should do to get it to run 11.5?
- Mitch.
XA WAGZ
GIFFO97
Has Liked: 128 times
Re: GIFFS XF
Postby EFFalcon » February 7th, 2013, 1:04 pm : Felony Likes this post
15psi should do it.
Re: GIFFS XF
Postby GIFFO97 » February 7th, 2013, 1:09 pm
EFFalcon wrote:15psi should do it.
Not to sure on whats been done on the inside. 15PSi would destroy it with Stock Internals most likely? I heard you can get CMS Kit's that make like 400 Horsepower without a Turbo for like 4 Grand?
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby Sunboost » February 7th, 2013, 1:30 pm : GIFFO97 Likes this post
Good pick-up bud. Saw this on eBay. Should come up alright with a little bit more work to finish it off!
Re: GIFFS XF
Postby TUFED6 » February 7th, 2013, 1:36 pm
Nice. I'd move that radiator header tank a bit further away from the exhaust if you can.
Re: GIFFS XF
Postby EFFalcon » February 7th, 2013, 1:42 pm
you won't be doing 11's N/A without stupid amounts of $$ thrown at it.
either nitrous or turbo, and given you're looking at LPG, then Turbo makes more sense.
stock motor will be pushing its luck with any thing more then 10psi, it can be done, and has been done a number of times though.
plenty of builds around here with details on whats needed for a quick car, atleast you have weight on your side.
Re: GIFFS XF
Postby GIFFO97 » February 7th, 2013, 2:06 pm
TUFED6 wrote:Nice. I'd move that radiator header tank a bit further away from the exhaust if you can.
Good point, Will look at doing that when i pick it up Saturday. And yeah, It was on eBay, and i got it a bit cheaper than what he wanted for it :D
True EF, I would like to keep it N/A for P's but I'm desperate to get 11's so will start saving for a Turbo.
Cheers, Mitch.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby sikwags_218 » February 7th, 2013, 4:28 pm : GIFFO97 Likes this post
I like it man not every day you so a xf with a ef/el dash conversion.
Nice pick up as sunny said will.come up mint with a bit of finishing off.
Defs needs boost :P
sikwags_218
Has Liked: 95 times
Re: GIFFS XF
Postby DJV8T5 » February 7th, 2013, 5:29 pm : GIFFO97 Likes this post
Looks like a nice clean car to start with mate, first XF I have seen with an EF dash in there, looks at home enough though. Nice first car too
Has Liked: 216 times
Been Liked: 88 times
Re: GIFFS XF
Postby NUT347 » February 7th, 2013, 6:12 pm : GIFFO97 Likes this post
Mint!
I reckon the first thing is get one of these > viewtopic.php?f=9&t=25150 and relocate your battery to the boot and that engine bay will look neat as.
Sick first car though, wish my first car was half as cool as that.
Also, if you turbo it leave it looking like it is haha.
Re: GIFFS XF
Postby GIFFO97 » February 7th, 2013, 6:24 pm
NUT347 wrote: I reckon the first thing is get one of these > viewtopic.php?f=9&t=25150
Does that get rid of the Radiator header? I will have a think about it.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby GUTLES » February 7th, 2013, 9:21 pm : GIFFO97 Likes this post
Saw this on your Facebook page. I like it a lot, will keep an eye out for it.
GUTLES
2004 Ford XR8
Re: GIFFS XF
Postby NUT347 » February 8th, 2013, 12:04 am : GIFFO97 Likes this post
Yeah mate, gets rid of the header tank.
Re: GIFFS XF
Postby BROCKYB8 » February 8th, 2013, 12:18 pm : GIFFO97 Likes this post
Looks good mate . LOve the xf ,.
Makes me miss mine .
NIce conversions thats for sure .
Re: GIFFS XF
Postby get_an_ea_today » February 8th, 2013, 7:01 pm : GIFFO97 Likes this post
Any more photos? Looks the goods.
get_an_ea_today
Has Liked: 139 times
Been Liked: 20 times
Re: GIFFS XF
Postby ford_racing_8 » February 8th, 2013, 7:16 pm : GIFFO97 Likes this post
This thing is pretty tuff, Awsome for a first car and a good clean base to start off with.
Previous Rides:
EA Fairmont
XE Ghia
EB Ghia V8 (TUFEB)
EB Fairmont
Current Rides:
BA II XR6 Turbo (Velocity)
AU XR8 Ute
ford_racing_8
Has Liked: 45 times
Been Liked: 29 times
Re: GIFFS XF
Postby GIFFO97 » February 9th, 2013, 5:27 pm
So i picked up the XF today, Theres a few things on it that i don't like. It hasn't got a handbrake and the exhaust has a hole in it, Needs a bit of a tidy up and a few things fixing on it for a Roady, but as do all cars. The Motor runs fine and the Auto shifts well, I found out that the Speedo is out 20kmph and 100k's, When i'm sitting on 100 I'm doing 123, Because of the XR6 Chip etc and the fact it's running a 2.77 Diff, If i put a 3.45 in it, It should get it back in range. Anyway she's a fixer upper and it'll eventually i'll get there. Now that I've got it, I'll let you chaps know what i payed, $1500, Good deal?
- Mitch,
Maccas Stop on the way home.... Bit of trouble getting it started again :P Theres a trick and thats tap the dash 3 times when you've got the key turned and then it'll crank over... Ain't no one gonna steal this thing!
At home...
As i said, The EF Dash, It needs a tidy up, Hoping to put some woodgrain in there i have some parts needed under the wanted topic if you care to check them out. The Dash has been cut to fit, And it wasn't too professional so i'll be fixing the sides up, Or possibly getting a new Crash Pad?
And saved the best for last Ehh, Will look into getting one of those Theromostat thingys to get rid of the header tank.
So what do you guys reckon? Bit of fixing up to do, But it'll make a good first car?
Cheers, Mitch.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby Bipolar » February 10th, 2013, 3:04 pm : GIFFO97 Likes this post
Yup :thumbsup:
Gonna leave it auto?
Re: GIFFS XF
Postby GIFFO97 » February 10th, 2013, 3:32 pm
Yep staying Auto :) Need to replace the power steering hoses as i have a leak :(
Also, Has anybody in VIC got a Venetian for it?
Cheers, Mitch.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby Michael (HYPOEB) » February 10th, 2013, 6:53 pm : GIFFO97 Likes this post
As everyone else has said, Really good first car mate!
BA XT Wagon: Stock.
EA SVO: Stock.
EBT-747: -
Michael (HYPOEB)
Been Liked: 261 times
1993 Ford Falcon
Re: GIFFS XF
Postby XHfalcon » February 10th, 2013, 11:48 pm : GIFFO97 Likes this post
If you wanna fix the starting issue I'm pretty sure it's the BCM my ef does it but like you I like my unintentional anti theft hahaha
EF xr6, Precision 75mm turbo, 6boost, Plazmaman Plenum, Wolf V550, C4, JE pistons....ETA on skids 6 weeks
XHfalcon
Has Liked: 7 times
Re: GIFFS XF
Postby SNR » February 10th, 2013, 11:57 pm
Needs more ED ghia front seats
SNR
Has Liked: 174 times
Re: GIFFS XF
Postby *rayman* » February 11th, 2013, 6:42 am
SNR wrote:Needs more ED ghia front seats
And twin headlight action...
I just so happen to have a set of XF/G XR6 lights for sale too..... $300 and they're yours. They would update the look quite a bit.
16" tickford rims look great on XF body shape too....
project: 68 BB Camaro
daily: 97 XH XR6 ute
previous rides: EB 5.0l GHIA, EF XR8, ED XR6, VT R8 Clubby, XF ute, and others not worth mentioning
*rayman*
Re: GIFFS XF
Postby GIFFO97 » February 11th, 2013, 7:31 am
Ill wait off on the XG lights, I need to fix the fuel sensor and the Speedo first before I start focusing on the body. Thanks for the offer anyway.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby braad » February 11th, 2013, 12:17 pm
GIFFO97 wrote: Need to get it to run better than an 11.5 just to show up an old friend and his dads WK Caprice
GIFFO97 wrote:So i picked up the XF today...
Done
braad
Has Liked: 175 times
1996 Ford XR-Ghia V8
Re: GIFFS XF
Postby GIFFO97 » February 12th, 2013, 4:37 pm
Haha Brad, Seems i have an Oil Leak. Depending on if it worsens i may rip the motor out towards April and rebuild the Internals etc. So when it's ready i can bolt a Turbo straight on and not have to worry about if the motor can or cannot handle it.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby ford_racing_8 » February 12th, 2013, 4:43 pm
When you start doing the exterior cosmetics, if your interested I found an XG grill in my shed.
Previous Rides:
EA Fairmont
XE Ghia
EB Ghia V8 (TUFEB)
EB Fairmont
Current Rides:
AU XR8 Ute
ford_racing_8
Has Liked: 45 times
Re: GIFFS XF
Postby GIFFO97 » February 12th, 2013, 4:47 pm
ford_racing_8 wrote:When you start doing the exterior cosmetics, if your interested I found an XG grill in my shed.
I found one on my dads XG :P I'm going down to Harveys his weekend to get some bits a pieces, If i can't find a White one i'll give you a buz.
Thanks, Mitch.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby Sunboost » February 12th, 2013, 6:58 pm
Sounds like a lot of loose ends. Will be light work if you're dedicated and handy though. Always the way with cars like these!
Re: GIFFS XF
Postby SnipeZ » February 12th, 2013, 7:23 pm : GIFFO97 Likes this post
If your ever in need of a hand give obsezd or me a pm. We're always located around cranny
1998 EL XR6 - Stolen
1997 EL Fairmont V8 - Current
5.0 V8
Full Leather
EL GT Headers
2"1/2 Twin System
FPV Dark Argent
Full Tickford Lip Kit
Low :)
Soon To Be Manual
SnipeZ
Has Liked: 235 times
Been Liked: 170 times
Re: GIFFS XF
Postby GIFFO97 » February 14th, 2013, 11:17 am
Stole dads bonnet because mine had a dent in it - XG Grille looks so much better too! Heading down the wreckers this weekend to get some bits and pieces. Hopefully they may have a DF/DL LTD which i can pinch some woodgrain from.
Also in the planning is to get rid of the XF Power windows on the doors and change it all over to EF/EL Power Windows in the Centre Console.
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby SnipeZ » February 14th, 2013, 11:21 am
No chance of the wood grain mate. Harvey's nope
Jollys nope.
It all goes
Buy Hus's spear.
5.0 V8
Full Leather
EL GT Headers
2"1/2 Twin System
FPV Dark Argent
Low :)
Soon To Be Manual
SnipeZ
Re: GIFFS XF
Postby GIFFO97 » February 14th, 2013, 11:25 am
SnipeZ wrote:Buy Hus's spear.
I can't afford it, That's why I'm going to Harveys :P Worth a look anyway, I got to get some Dash vents, Power Steering pump and a few bits an pieces anyway :)
XA WAGZ
GIFFO97
Re: GIFFS XF
Postby Bipolar » February 14th, 2013, 1:02 pm : GIFFO97, NUT347 Likes this post
The middle lower of my XF's front bar used to bow upwards too.
Man props to you just for being 15, typing properly and not talking any shit. Historically uncommon on these forums.
Re: GIFFS XF
Postby BROCKYB8 » February 14th, 2013, 1:15 pm
I have a spare front bar for xf as welll custome door trims :)
Re: GIFFS XF
Postby KR1STO » February 14th, 2013, 1:23 pm
Great first car mate..!
Miss my old Ghia..
I've got heaps of XF parts laying around, so if ya need anything feel free to pm me and I'll see if I've got it..!
Good luck with it mate..!
KR1STO
Been Liked: 25 times
Re: GIFFS XF
Postby private9 » February 14th, 2013, 1:41 pm : GIFFO97 Likes this post
Cool first ride mate! Tick off all the small things one by one, and you'll have it all sorted in no time.
private9
Been Liked: 185 times
Re: GIFFS XF
Postby SnipeZ » February 14th, 2013, 2:14 pm
Bipolar wrote:Man props to you just for being 15, typing properly and not talking any shit. Historically uncommon on these forums.
+1 most of the young ones give chronic headaches
5.0 V8
Full Leather
EL GT Headers
2"1/2 Twin System
FPV Dark Argent
Low :)
Soon To Be Manual
SnipeZ
Re: GIFFS XF
Postby BROCKYB8 » February 14th, 2013, 3:21 pm : GIFFO97 Likes this post
You should get some xf rims for it too . THe real ghia rims would look really nice on these .
Im pretty sure the ones on it are ea ones
Re: GIFFS XF
Postby GIFFO97 » February 16th, 2013, 7:16 pm
Maybe???
XA WAGZ
GIFFO97
