Might as well update my thread. Car has had massive work done to it.
Engine was ripped out as it was blowing a shitload of smoke, main bearings etc all fucked. Once it was pulled out it was sent of for a complete rebuild, i had told the builder that the car will be running boost later in the future so stronger oversized pistons were put in 40 thou. Block was chemically cleaned, deck, honed, balanced, and all painted. Head was fully rebuilt and my rocker cover was sent of to get powder coated as i was sick of it chipping off. New timing cover, chain, welsh plugs, oil pump were also put on
Whilist the engine was getting rebuilt i decided to buy all the accessories new as the existing ones were farked from the sludge. New coilpack, eagle leads, alternator, water pump, powerbond balancer,thermostat housing upper and lower, full gates hoses including heater tap, idler pulley, radiator, coolant bottle and battery were all purchased. i scored a set of paceys cheap and got a ballastic 100cpsi cat put on to it too as the stock ones looked shit. Every single nut was cleaned a resprayed throttle body and BBM was soaked in degreaser as there was oil inside them all.
When i got the engine back i was told it had already been rebuilt before as it was 20thou already over, mind you the car has only done 210,000km? once the engine was home i decided to detail the engine bay and polish it all up before the motor was dropped in. The whole gas system was also ripped out as its caused nothing but headaches since day 1.
Car is now running VERY well with not 1 drama so far, runs a lot smoother and goes a lot better. Turned first go which was good no work needed to be done in order to fire it up.
Im now in the process of replacing every bush in the car as well as new steering rack, ball joints , tie road ends and 30mm whiteline swaybar thanks to justin at tuff car parts online!!, . I also scored rear venetians from a guy in geelong.
plans now are for the car to go in for a complete respray in the same factory colour but with high metallic mixed with house of kolor ultra thin flakes. Might also try whitewalls on it LEGALS of course as it gets attention already. But really im just enjoying it and im looking forward to boosting it!
Here are some pics of the car enjoy
