hi everyone
bought a ef fairmont 4.0 back in july 2012 and since then been doing quite a lot to it.
in 2012 a month after getting car got it put back on lpg and then got a sports exhaust for it and put it on, and then got extractors for it and had trouble getting them to seal and patched them up.
then in 2013 took the first sports exhaust off and extractors off and got a redback exhaust and a better set of extractors and fitted it all and much better after that.
later 2013 got a set of au injectors as the old ones were worn out and also got a xr6 computer and tried it.
in 2014-2015 got a fairlane interior and in 2015 bought dl ltd electric seat bases (just need the electric backs though do have the motors, shouldve got the backs too)
from 2016 to now been doing alot of jobs some bigger than others. and blew a head gasket so just patched it up with sealer to hopefuly keep it going for a bit and got the water pump heater pipe modified (just cut it behind bracket behind water pump and got some bends and brought it out other way and got a brass fitting welded and just got heater hose running around side which is alot easier.
in 2017 got a larger radiator and cooler thermostat, then got a new heater pipe for the thermostat housing and later that year had to get a new fuel pump as that went because it wasnt run much on petrol like it should every so often. also replaced the sender assembly as it was rusted out from sitting in old stale petrol, but using a eb/ed one because want the push on hose and clamp not the quick disconnect
thanks
