Been a busy few weeks on the EB! New engine in & running, tHermos wired in, BBM wired in, serpentine setup, Dizzy setup, redid the loom for injectors/dizzy/TPS/all that jazz. New sump gasket, front & rear main, water pump, radiator, hoses, power steering H/P hose, & rocker cover gasket. Used some of that hylomar stuff, I'm impressed! Works quite well.
Gutted the impco 200 gas system from dads old wagon and put it on instead of the bbq ring. Wired it all up as per original (fuel pump shutoff relay, injector shutoff relay, etc). Only have to install the switch in the dash properly. Runs soooo much better with a decent management setup.
Rear wheel has been changed back to the EB-s rim, as it was about to implode. Will be changing all 4 back to these as I have a set with new tyres. And until I can get the 4th GTP fixed.
Camber kit installed on the front.
Tuned the gas setup. Drove to a job interview with the dash half out, was a bit urgent lol.
Hooked the cruise system up. Made an EL cable fit the EB module. Was going to jerry-rig the EL module into it, as its way more compact (1 device not 3), but didnt have the time. And wasnt sure if the VSS signal from the ECU would be enough (dont you need one from the cluster?) SO just modified it.
New rear seal on the gearbox as it was leaking.
Yet to fit the EL A/C pump and drier/condenser or whatever its all called. The EF pump I have accidentally got pressure washed (ie filled with water
) when I cleaned the engine.
Also am going to paint the rocker cover once all the kinks have been sorted.
A few pics of the finished setup:
The gas system:
New shifter & steering wheel:
Munched wheel:
PS does anyone know how the impco systems do their petrol start if there is no actual petrol start controller? Did some work with out the module? Mine has the commander ECU, and is all connected, but doesnt seem to get enough fuel on startup. Pops and farts for a second then the gas switches on (relays click) and its all good. Petrol is fine. Did the same thing when the gas system was in the EL.
Any ideas?
1974 XB GT
here, 1975 XB GT, 1972 XA GT, 1970 Mach 1 Mustang, 1946 Jailbar, 1983 XE GL, KTM 200EXC, XT500SM & various wrecks
EB Falcon, AU2 XR8, AU3 XR6
here
1992 Nissan Patrol - 2" lift, 33s, TB42e, LPG
here
2014 FG GT 335 - Silhouette, ZF
here
