GT wing on an EB
bazza_2011
GT wing on an EB
Post by bazza_2011 »
Hello
I brought an aftermarket EB GT wing for my car, but it didnt come with bolts or anything to mount it with. So
i was wondering, what size bolts are required to secure the wing to my boot lid? Also the wing has nothing
inside the mounting holes for a screw or a threaded bolt to thread onto.
Any help that i could get would be greatly apprieciated.
Thanks
Baz
Re: GT wing on an EB
Post by nstg8a »
did you buy it new?
sounds like when it was made they forgot to put the threads in the mould.
Post by LUXO_8 »
you're just going to have to devise a way..... drill some holes down through the top. mount some big **** off bolts in it then bog the holes up.....
Post by nstg8a »
^^sounds brutal, but i cant think of any other way.
or just sikaflex the wing on... might work. for a while.
XR_Lightning
Post by XR_Lightning »
brutal, but atleast it will hold unlike just sikaflex, how else do you think spoilers are held on? they always have nuts & bolts, so Wayne's suggestion was very valid...
Post by nstg8a »
XR_Lightning wrote:brutal, but atleast it will hold unlike just sikaflex, how else do you think spoilers are held on? they always have nuts & bolts, so Wayne's suggestion was very valid...
i wasnt disagreeing with him...
oneredED
Post by oneredED »
If you could get a really beefy version of the first picture, it might just work. No idea how it would hold up though haha.
OR
2013 VW Up!
2014 KTM 250SX-F
AUIII Ute
Post by holmsy »
drill into the bottom. bolt from in the boot.
put something like 2nd pic onereded just posted.
it should grab in enough to hold.
XR_Lightning
what is the mounting surface of the spoiler like?? maybe you could make a thread in it and screw some studs in there with loctite so they dont screw out, then just drill some holes in your boot and put some nuts on the other side of the boot, and use some sikaflex around the base of the spoiler aswell, for added security and to seal against water and dirt
OMY-747
Post by OMY-747 »
Are the feet solid? Or they hollow with just a base plate? Depending on how they are will depend on the best way to go about it.
If its just a base plate you can go into bunnings and look at all the heavy duty mounts for hanging stuff straight off plaster, like the 2 pictures onereded posted up.
( on a side note, my 1000th post :drinks2: )
Simo
Post by Simo »
When I did mine i used some threaded rivets.
they work well
http://www.rivetsinstock.com/rivet-nuts ... serts.html" onclick="window.open(this.href);return false;
Ford EF Falcon:
16" alloy xr rims , Ef xr body kit, Lowerd on sl king springs, Xr6 lip spoiler, el xr6 front bumper, Hid's 8000k, Paccies 4499 with high flow cat and 2.5 in exhaust nd hotdog, big mouth ss induction, k&n panel filter, big sound
