FG Falcon Engine
FG Falcon Engine
Has anyone seen the pics of the FG's motor... more noticably the intake manifold
- Bomber
- Full Boost
- Contact:
Re: FG Falcon Engine
Throttle Body is also facing the other way, wonder if swanny will buy one and claim heat soak in the plastic manifold when at the drags!
Yeah they've mentioned the different manifold when talking about the XR6T a fair bit.
first photo i've seen of it.
it almost looks like an engineering evaluation part or something.
I know the external ribbing is designed to enhance induction noise.
I wonder how much it will cost to replace when it splits from gas backfire.
i would be very interested in the internals of the manifold.
i thought the I6 was suppsed to be dropped and the V6 its replacement? looks to me like a stock barra engine
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual - 315rwkw
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
- Fairmont888
- Spooling Up
arent they only stopping production of the I6 in 2010 because thats when the engine plant is closing or whatever?
the I6 is here until 2010 or 2011 or something.
the I6 is putting out 195kw now i think?
The I6 will be dropped in 2010.
Who's going to the Motor Show on Friday?
- Fairmont888
- Spooling Up
im flying down there on saturday
This was what I was thinking.Sundeep wrote:I wonder how much it will cost to replace when it splits from gas backfire.
I think you will find they will have gas injection, with a vent on the manifold that will open in the event of a backfire. A bit like what they have done on the 5.4L 3v F150 and F350s
- Nikk O'lass
- Full Boost
The XR6T gets shorter pipe work compared with the BA/F and has a more 'normal' FMIC with inlet on the drivers side and outlet on the pass side, thats got to be better for the throttle responce!
GT's get a twin throttle body!
Yeah the TB faces the other way - one reason in particular was shorter piping like Nikk said. The manifold itself is not normal plastic (I know Ford Oz is stupid, but not that stupid... Then again...). It's a plastic/composite material so it's not that likely to break like the shitty stuff found on earlier models.
Golf GTI
have you seen my stereo? FAIL
You're right, its a nylon/glass type composite. Can't remember exactly but it's just normal airbox plastic.
It's still essentially plastic then. Even if it's strong it'd split at the seams and sht under a heavy backfire.
It helps drone out the noise the 6 cyl exhaust makes.Bipolar wrote:I know the external ribbing is designed to enhance induction noise.
John, I heard they were going to be putting out 205kw in stocko form.
I guess to trump the Aurion and so on.
Blown EL XR8
- Fairmont888
- Spooling Up
Listed as having 195kw on fords websiteEL XR8 wrote:John, I heard they were going to be putting out 205kw in stocko form. I guess to trump the Aurion and so on.
Fairmont888 wrote:Listed as having 195kw on fords websiteEL XR8 wrote:John, I heard they were going to be putting out 205kw in stocko form. I guess to trump the Aurion and so on.
Ahh bugger. I don't know where i heard that info from then. Someone talking shit though... obviously.
Blown EL XR8
I think the new falcon might have a water intercooler, because there was a box on top of the engine that was leading from the turbo into the intake manifold and it said intercooler on it. was on a picture i saw, if i find it i will post it up.
I thought the E-Gas models were injected LPG this time around, I sware my mates BF2 RTV is injected LPG - EGAS green head
- SnyperEB
- Shooting Flames
Ford really know how to make ugly things dont they!! They started at the AU!!
They always have that written on them... refers to the air-to-air intercooler.Jake wrote:I think the new falcon might have a water intercooler, because there was a box on top of the engine that was leading from the turbo into the intake manifold and it said intercooler on it. was on a picture i saw, if i find it i will post it up.
wet towels
It has shorter and longer piping. The longer path is used until a valve flap closes it off and directs air to the shorter path at 3750rpm for better throttle response. The flap then turns to close off the shorter path and direct air back to the longer paths at 5500.XRated wrote:Yeah the TB faces the other way - one reason in particular was shorter piping like Nikk said.
Wow, the fifth comment I've ever written in one of these things actually got posted for once, even though it was way after I submitted it - http://www.news.com.au/couriermail/comm ... 60,00.html
All I have to say is, I wonder how easy it will be to drop that in a e-series.
BF MkI XR6T
- galapogos01
- Hitting N2O
i posted about this intake in the other thread! pretty good i reckon. major weight saving, and its not going to crack as it's a composite plastic. many other cars have been using plastic intakes for years.
i still cant get over how many refinements they made to an engine theyre binning in 2 years.
nfi about the FG tho, there's really been no mention of the base models in the launch.
BF2 E-Gas != injected. my old man has one. Practically the same kit ford's been using since the EL Tickford dual-fuel option, ECU controlled fuel stepper solenoid, mixer ring in the intake, complex convertor, spring clips on the airbox.Frost wrote:I thought the E-Gas models were injected LPG this time around, I sware my mates BF2 RTV is injected LPG - EGAS green head
- Fairmont888
- Spooling Up
lol i read that... unfortunately i couldnt read the whole thing because i got sick of people who clearly know nothing dribbling about how its the exact same carBipolar wrote:Wow, the fifth comment I've ever written in one of these things actually got posted for once, even though it was way after I submitted it - http://www.news.com.au/couriermail/comm ... 60,00.html
And finished with the AU.SnyperEB wrote:Ford really know how to make ugly things dont they!! They started at the AU!!
- Nikk O'lass
- Full Boost
Keep in mind its the same plastic that is used on most radiator supports these days (FG gets a bolt in plastic support aswell), it's fairly tough. But i guess it still has a chance.Sundeep wrote:It's still essentially plastic then. Even if it's strong it'd split at the seams and sht under a heavy backfire.
- Nikk O'lass
- Full Boost
i was talking about a short track from the turbo/airbox to the TB...What you described sounds likt the Broadband manifold...Bipolar wrote:It has shorter and longer piping. The longer path is used until a valve flap closes it off and directs air to the shorter path at 3750rpm for better throttle response. The flap then turns to close off the shorter path and direct air back to the longer paths at 5500.XRated wrote:Yeah the TB faces the other way - one reason in particular was shorter piping like Nikk said.
makvaiielles_xr6
- Idling
the ribs on the out side is a good idea though. i showed a mate who rallys and he said they gut the inside of manifold to improve breathing hence the power and efficiency ratings. it also mentioned they are now putting higher quality internals...YAY
LIL TOY- Escort p/van
MID TOY- 96 EF XR6
BIG TOY- 66 Galaxie
MID TOY- 96 EF XR6
BIG TOY- 66 Galaxie
galapogos01 wrote:i posted about this intake in the other thread! pretty good i reckon. major weight saving, and its not going to crack as it's a composite plastic. many other cars have been using plastic intakes for years.
How is using a mixing ring injected gas? Injected gas uses Injectors.
E-Gas is being launched in May
First mod would be to piss that drive by wire system off. The only reason I'll never buy a later model falcon, oh and that electronic stability control. Drove a Mazda MPS (slow piece of crap) BF XR8 (yawn) and drive a BF 2 ute for the (RACV) and all give me the s%^ts
- galapogos01
- Hitting N2O
Frost wrote: How is using a mixing ring injected gas? Injected gas uses Injectors.
err... i said BF2 is NOT injected?
Whats wrong with the drive by wire stuff. ATM i would prefer it, cause its better than my throttle cable that sticks (closed) so its no problem, but fucking annoying every now and then.t2te50 wrote:First mod would be to piss that drive by wire system off. The only reason I'll never buy a later model falcon, oh and that electronic stability control. Drove a Mazda MPS (slow piece of crap) BF XR8 (yawn) and drive a BF 2 ute for the (RACV) and all give me the s%^ts
I don't know what world you're from. Those Mazda 3 MPS', move along very fucking well, and being Mazda, they'll last for donkey's year, have good resale, and they look good.
Blown EL XR8
- Steady
- Breaking Intake Welds
Hes from the world of T3 envy and poor taste in vehicle aesthetics.
T3s are mint
MPS arent exactly slow, arent they just an XR5 in a different shell?
Nah an XR5 is Shaun's EB when it drops a cylinder at AFD
